I noticed my cnc router is cutting undersized.... the machine is only a month old... i thought it was software related, but ive ruled that out... i was told to look for machine flex... I went over ever screw and they were all tight... but found that my top Y axis bearing seem to slightly rattle on the shaft if i pulled lightly on the spindle (router)... I decided to pull them out.... first thing i want to know should there be grease in them?.... and when you shake the bearings should the balls rattle in the bearing?.... any thought on this would be great.... thanks
