587,197 active members*
2,806 visitors online*
IndustryArena Forum > CAM Software > CamWorks > license keep changing
    Jul 2005
    1650
    I have Solidworks13/Camworks13 at work and for some reason the license keep changing I have to go into License info and check the box for the available license and update it so I can use that license I have to check the box that feature is there a way that I can set it so that I don't always have to be updating so that its correct. I am on a network and am using the flexLM license it is a commercial license. not sure if I explained it correctly and if I didn't I apologize .
    Mar 2008
    111
    Re: license keep changing
    If it isn't rembering what you are setting as "on startup" then you don't have adequate user permissions, get your it guys to give you admin right or peer user rights
    Jul 2005
    1650
    actually I can have a file open run simulation and go back to change something and wont be able to edit the definition because the access to say the 2.5 axis module will become unchecked .. so I don't think I have a user permission issue it may be a bug in the software just wondering if anyone else has seen this
  1. had a trial license
    By anddy26 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-05-2014, 08:17 PM
  2. ViaCad License
    By RTP_Burnsville in forum ViaCad / Shark
    Last Post: 03-06-2014, 11:06 PM
  3. Win a License of CamBam!!!
    By jwolin in forum WoodWorking Topics
    Last Post: 12-06-2012, 09:16 PM
  4. Alibre license features changing?
    By dblox in forum Uncategorised CAD Discussion
    Last Post: 09-25-2011, 01:56 AM
  5. Would like to buy an XR2 license
    By bobp in forum OneCNC
    Last Post: 06-29-2008, 06:39 AM
