587,300 active members*
3,166 visitors online*
Results 1 to 2 of 2
    Jan 2014
    3
    Lets Talk About End Mills
    Hi Everyone,
    So, we just got a new Vertical CNC, and its pretty much set up, and we're ready to start cutting.
    We're making some wooden iPhone accessories, and I was wondering if anyone had any recommendations on what kinds of end mills to use?
    I was reading recently that full depth cutting is a good idea, because it wears the end mill out more evenly, and I have a few profile cuts in some 3/4" pieces, that Id love to get in one pass.
    We've just been using 1/8" router bits from home depot, but should we look for something better at woodcraft or somewhere like that?
    Anyone have any strong opinions?
    Thanks,
    Evan
    35538
    Re: Lets Talk About End Mills
    Without seeing exactly what you're doing, it's hard to make recommendations.
    You're not going to be able to make a 3/4" deep pass with a 1/8" tool.
    If your making small things with small tools, then you don't have a lot of options. Usually, cutting small details with large tools causes damaged parts.
    But it really depends on the exact operations that you'll be doing to give any kind of recommendation.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. lets talk bearings (Mini Mill x2)
    By ZipSnipe in forum Mechanical Calculations/Engineering Design
    Last Post: 05-03-2013, 06:57 AM
  2. Lets talk about BRUTE machines....WOW
    By carbidecraters in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2010, 08:23 PM
  3. Lets talk feed rates (milling)
    By MBG in forum Haas Mills
    Last Post: 08-07-2009, 11:32 PM
  4. Lets talk feed rates (milling)
    By MBG in forum Haas Lathes
    Last Post: 07-28-2009, 10:37 AM
  5. Lets talk financing
    By carbidecraters in forum MetalWork Discussion
    Last Post: 04-18-2006, 08:00 AM
