587,472 active members*
2,940 visitors online*
    Feb 2005
    5
    Learning from scratch
    I have always wanted to be able to design something on a computer, then send it to a machine then watch it do its magic. Since having a workplace accident and now have limited physical abilities, and a strong interest in CAD, seeing these mills opens up a whole new & exciting path for me.
    However I am starting at the ground up, can anyone tell me what I need to know when it comes to doing a drawing in cad or Rhino, what happens next.
    I have a Taig micro mill and the box, what do I do or need next.
    If anyone can set me on the right path, I think you will see some interesting thing I have planned for this as a base entry, then for the Homebrew 5ftx12ft model I wish to build when I have worked out what to do.
    Please help if you can, I am very serious about this venture.
    Kitch02
    35538
    Depending on the type of drawing, you'd use something like either SheetCAM http://www.sheetcam.com or MeshCAM http://grzsoftware.com to generate gcode from the drawing for the machine to run.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2005
    5
    Thanks for the info Gerry, I will give it a go.
    Can you have a look at my other post and see if you think it can be done?
  1. Another learning module
    By Chunky in forum G-Code Programing
    Last Post: 06-11-2005, 11:04 AM
  2. learning to g-code
    By bush666au in forum G-Code Programing
    Last Post: 04-06-2004, 12:02 PM
  3. Could use some advise on learning CNC?
    By Beezer in forum Uncategorised CAM Discussion
    Last Post: 03-06-2004, 07:12 PM
  4. Mastercam Home Learning
    By motomitch1 in forum Mastercam
    Last Post: 11-21-2003, 02:13 PM
  5. learning to model
    By HuFlungDung in forum OneCNC
    Last Post: 04-18-2003, 07:01 PM
