587,345 active members*
3,693 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Lead out setting for 2 circle same (center)
Results 1 to 4 of 4
    Feb 2009
    14
    I use MasterCam X3, wire EDM,
    Two circle with same center point, The inner start cut from inside and outter is start cut from out side,
    I don't know how to select toolpath for 2 circle at same time? (mastercam only have inside or outside in lead out setting!!).
    Nov 2006
    418
    I think if you reverse the direction of one in relation to the other it will make the lead-in move be opposing each other in direction... Seems that is what it has done to me when selecting circles for milling.
    Feb 2009
    14
    John_B, I tried your way but "not success" !.
    Can you tell me more detail about parameters setting ?
    Thank you.
    Dec 2008
    3124
    The trick is how you select the chain/s ( your closed chain is selected by the entity that you select first, with the nearest endpoint being the start point of the chain )
    ( this assumes that the start point of the circles is at the 3 o'clock position ( zero degrees )
    So for the two circles
    inner circle, select above the RH quadrant point on the circle ( it will show 2 arrows ( big for direction - should point CCW, small for the cutting side -should point to the centre )
    outer circle, select below the RH quadrant of the outer circle ( big arrow points CW, small arrow point outwards )
    if you do select wrong, that chain can be reversed using the red arrows in the "Chaining" dialog box. Or you can delete that selection & re-select to go the correct way
    ( for the "chaining" dialog box - hit the cheveron, in the upper LH corner, for additional advanced options ( moving start points etc.))
    PS - avoid using the WINDOW to select entities, always pick the chain
  1. Replies: 2
    Last Post: 07-15-2011, 12:36 AM
  2. Find center of circle
    By dano9700 in forum Engraving Machines
    Last Post: 12-16-2010, 02:19 AM
  3. find center point of circle
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 10-10-2010, 08:34 AM
  4. New lead screws, setting EMC to them
    By g29cc in forum LinuxCNC (formerly EMC2)
    Last Post: 08-11-2009, 11:03 PM
  5. Find the center of a circle
    By Hobbiest in forum WoodWorking Topics
    Last Post: 01-28-2004, 06:24 AM
