!We picked up a WKLaser direct from china. Here are some notes..
Ordering was easy enough, $700ish to broker it.
about 6 nuts and bolts came loose in shipping, mostly the doors. half of the locks were stripped at the back, easy to fix. they are standard locks.
One of the mirrors was loose, we replaced them all with II-VI's and realigned everything. The mirrors were dirty out of the factory, the focus lens was covered in black specs (on the topside)
Small crack in the case on the upper front left side where its hinged, the welds gave way. reasonably easy fix.
Airflow seems odd for the suction, not sure yet why the back is open? (ohh for long boards derp)
Poor grounding, the gantry is not properly grounded to the chassis, check it and fix it.
Internal fluorescent burned out after a couple of days (black edges) its a T4 28" tube
Gantry isn't aligned to the table properly or the chassis, cheapy plastic blocks instead, easy to rebuild and fix.
I don't like that home's automatically when you switch it on, but that's a minor thing.
Z table is a bit shonky but it more or less works, its easy to get it out of alignment.
honeycomb/razors just sit on the work table, they can move off and get jammed, double sided tape fixes it but something to affix it would be better.
LaserCut5.3 Software is ok, locked up a few times. bit slow, but easy to use, don't like that it is dongled. installed easily enough on windows, CD's supplied had one scratch on it, and one of the SHX fonts was unreadable but i found it online.
Initially we were going to build our own controller for it, but the leetro hardware seems ok, it needs some shielding though. the current idea is just to write our own printer driver around the leetro DLL's instead.
Also been looking at the reci W6? with the dy20 psu replacement, the machine has a suitable cut out for an extension box. (quoted $1500 plus shipping)
So far its been pretty good, under $4,000K. Pretty happy with it overall, definitely room for improvement but nothing that's been a deal killer, though the grounding needs to be better.
we're gonna get the rotary attachment, though i almost died laughing when i saw some people want $1,000 for it.
tonight we took apart the z table so that we could align it, the hpde/nylon bearings use to lift the table were loose too, so when it changed direction it lurched.
the two steppers to lift the Z table are connected together and driven by one controller.
we took lots of pictures and are going to write a longer post with details on everything we've found and fixed. We will probably replace the entire case since nothing is square or aligned to anything else.
