587,482 active members*
3,309 visitors online*
Results 1 to 4 of 4
    Feb 2004
    27
    Lazy cam z=60?
    I am using lazy cam to create my tool path from a dxf file from Bobcam. My z is always coming out on 60 before plasma torch on (m03). Does anyone have any ideas? I am using Lazy Cam in the plasma mode.
    John
    Dec 2004
    43
    Hey, a question maybe I can answer!!!
    I had the same issue.
    click on the "layers" tab, then enter your desired height.
    at least I think thats how i did it.
    In the end I still use sheetcam
    Feb 2004
    27
    Thanks John really simpe fix. Have not been working with Lc long mostly use Bobcadcam. One quick question about sheet cam can you nest in that program?
    John
    Dec 2004
    43
    Yep, you can. There is even a tutorial in the program to show you how.
    One thing I didn't catch on to right away was how to open different drawings on the same screen. Quite simple though... under the file menu, choose "open new part".
    HTH , John
  1. Mach3 Lazy Cam
    By mxtras in forum Mach Mill
    Last Post: 10-14-2009, 05:54 PM
  2. Lazy Cam probs
    By DRP in forum Screen Layouts, Post Processors & Misc
    Last Post: 09-10-2007, 09:37 PM
  3. lazy cam help
    By andrewbishop66 in forum Mach Wizards, Macros, & Addons
    Last Post: 05-27-2007, 11:05 PM
  4. Lazy Cam for Mach3 ( Sneak preview video)
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2006, 12:18 AM
