Ronny,
If you go the dc brushed motor way there are also devices around that will allow you to put an encoder on your motor instead of a tachometer. These devices allow you to input a pwm frequency for programmed speed control, or from a pot, as well as a step and direction input. This will allow you to switch between velcity and axis control modes, thus giving you the ability to have a spindle speed controller and the ability to lock the spindle in with the other axes on your lathe and drive it as a rotary device for live tool milling or controlled thread cutting.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
