fordav11
That makes a lot of sense, the guy will bw here in 4 days and I will come back to you on what he says is the problem.I think your initial 'trouble' with tool setting using the probe is that the probe is not calibrated so using it gives incorrect values. use the manual tool setting method I described above. once you have that working the procedure to calibrate the probe can be followed and you can cross-reference your correctly set tools to make sure the values are the same.
Thanks for the help its much appricated.
Tony
