587,216 active members*
2,561 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Lathe gang tooling and dowel pin questions
    I'm building a small gang tooled lathe. Here is the full build thread: http://cnczone.com/forums/showthread.php?t=92337
    I'm ready to figure out how to attach the tooling to the tooling plate.
    My thoughts so far are to use two dowel pins and one bolt for each tool holder. o=hole for dowel pin, x=threaded hole for bolt
    o x o
    o x o
    o x o
    o x o
    o x o
    If I can do this accurately I can drop tools on and have them be accurately located in X and Z. Open to suggestions.
    I've never used dowel pins before. Tooling plate is ground O1 tool steel. Here is my plan so far. Spot drill, drill with C drill (.242"), ream with .251" reamer. Open to suggestions.
    Thanks, --Will
    Feb 2008
    586
    I'd use locating pins like this. A little more forgiving than two dowel pin locators.
    I get the redundent locating idea. Could I get away with grinding some flats on a dowel pin instead of paying for a fancy locating pin?
  1. Gang tooling help..
    By roger_e in forum Vertical Mill, Lathe Project Log
    Last Post: 01-30-2010, 01:03 AM
  2. School TL-1 and gang tooling
    By TEntpeg in forum Haas Lathes
    Last Post: 12-13-2009, 10:04 PM
  3. Gang tooling
    By lcarrudajr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-08-2009, 10:47 PM
  4. Gang tooling vs turret
    By baldysm in forum Uncategorised MetalWorking Machines
    Last Post: 12-03-2007, 11:47 PM
  5. Gang tooling vs turret
    By baldysm in forum CNC Tooling
    Last Post: 11-29-2007, 06:03 AM
