587,308 active members*
3,645 visitors online*
Results 1 to 5 of 5
    Dec 2008
    46
    Lathe Diameter mode on wireless MPG
    Hello,
    I've installed the last upgrade of TNG which include the diameter mode on X axis display for lathe type machine.
    But I'm not able to see the same on the display of original wireless MPG.
    It's possible to have the same value on both display? I've not found the setting for that.
    Mar 2017
    1328
    Re: Lathe Diameter mode on wireless MPG
    I've implemented this and will be in next beta version.
    Mar 2017
    1328
    You can get beta version here:
    https://test.planet-cnc.com/download.html
    Dec 2008
    46
    Thank you for reply.
    Could I have other problems with the beta version, or can I install it peacefully?
    Mar 2017
    1328
    Some parameter names were changed. This could affect any custom scripts you have.
    1. Create a copy of PlanetCNC installation folder (normally this includes all your profiles)
    2. Extract .exe and two .dll files from BETA .zip and replace existing files
    3. Now you have both versions installed simultaneously. Firmware is the same so you can use which one you want.
    I recommend that you do this because eventually BETA will become current.
    Everything is ready except some parameters need to be documented:
    https://cnc.zone/tng/parameters/parameters
    And I'm doing minor tweaks like the one you requested.
  1. Lathe Diameter Mode.
    By blowlamp in forum PlanetCNC
    Last Post: 12-04-2023, 04:42 PM
  2. Replies: 10
    Last Post: 12-14-2022, 07:35 PM
  3. No negative z-numbers on wireless MPG
    By JerryBurks in forum PlanetCNC
    Last Post: 05-15-2020, 01:53 AM
  4. wireless MPG for Mach3
    By fresko in forum Machines running Mach Software
    Last Post: 04-19-2014, 08:15 AM
  5. WIRELESS MPG
    By davidponte in forum Mach Mill
    Last Post: 10-29-2012, 10:58 PM
