587,842 active members*
3,332 visitors online*
Results 1 to 2 of 2
    Oct 2013
    2
    Laser prefference for 1" or 2" polyethylene 4lb foam
    Does anyone have any recommendations on a laser machine to cut closed cell foam with?
    Currently using a Universal Laser PLS6.6 with 2" lens.
    Considering trotec 300, or maybe Kern but the price is too high. The foam is generally about 15" x 15" 2" thick polyethylene 2lb or 4lb would be preferred.
    Every piece is custom and this would be for high volume say 50 pieces a week. I could use advise on laser power lense and so forth.
    Thanks in advance for any help.
    Josh
    Depth Of Field is going to be a problem Josh, (the distance the beam will travel while staying straight) A cut will end up like this ^ on thick materials unless you use a VERY long focal length lens.
    Although well outside my field maybe a hot wire cutter would do the job better? (and possibly cheaper) this is just a guess though, I know nothing about hot wire machines.
    cheers
    Dave
  1. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  2. original "laser" & "mulrec" files
    By medmouncef in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-10-2012, 08:38 AM
  3. Replies: 1
    Last Post: 01-14-2011, 04:43 AM
  4. Wire for foam Cutting "EdgeSweets" machine
    By singerdon49 in forum Employment Opportunity
    Last Post: 12-29-2008, 03:12 PM
