586,555 active members*
3,447 visitors online*
IndustryArena Forum: Laser Hardware
Page 3 of 17 1234513
Threads 41 to 60 of 324
Discuss Laser Hardware here!
Sub-Forums Threads / Posts  Last Post
  1. Laser CO2 Tubes, Diodes, RF and Power Supplies here.
    Forum Actions:
    Forum Statistics:
  1. Power Supply for Reci W4 100-130W?
    Started by Jimmyalenius, 03-18-2021 03:00 PM
    100-130w, power, reci, supply, tubes
    03-18-2021, 03:00 PM Go to last post
  2. Trying to build my own CNC Laser cutter
    Started by brainy19, 02-18-2021 10:06 AM
    cnc, cutter, laser, module, needed
    03-18-2021, 06:51 AM Go to last post
  3. How hard can I drive it?
    Started by aadesh119, 02-25-2021 06:04 AM
    03-01-2021, 03:19 PM Go to last post
  4. HL-1060 100W homing issue
    Started by Driven2112, 01-12-2021 02:45 AM
    02-21-2021, 11:22 PM Go to last post
  5. Noise on 45W CO2 laser
    Started by frStudent, 01-31-2021 01:39 PM
    01-31-2021, 04:56 PM Go to last post
  6. Stepper Motor Vibrating
    Started by 31ThreeDesign, 01-05-2021 07:37 PM
    cnc etching motor issues, cnc motor, vibrating motor, wires, wiring problem
    01-06-2021, 01:53 PM Go to last post
    01-03-2021, 07:41 PM Go to last post
    12-30-2020, 12:38 AM Go to last post
  7. High woltage connector burned
    Started by Johnlaser120, 12-19-2020 08:22 AM
    12-19-2020, 08:22 AM Go to last post
  8. Question 2.5W or 5.5W laser ?
    Started by RobboRobbo, 11-20-2020 05:24 PM
    cnc 3018, cnc3018, engrave, laser, software
    11-21-2020, 11:52 AM Go to last post
  9. Question CW-5200 Relay diagram
    Started by MonsieurFredo, 11-17-2020 04:25 PM
    11-17-2020, 04:25 PM Go to last post
  10. 4 burn marks on a newly replaced laser...
    Started by amy_stars, 10-23-2020 12:09 PM
    10-23-2020, 12:09 PM Go to last post
  11. looking for replacement laser
    Started by jonnyA, 08-27-2020 02:47 AM
    09-30-2020, 02:30 PM Go to last post
  12. Lightbulb Laser marking machine focus method
    Started by youbencnc, 09-24-2020 10:38 AM
    focal, laser, length, marking, software
    09-24-2020, 10:38 AM Go to last post
  13. China Laser 50W cut issue
    Started by Loit, 09-09-2020 07:32 PM
    09-10-2020, 01:41 AM Go to last post
    08-06-2020, 03:34 AM Go to last post
  14. Tube and power supply upgrade
    Started by andbad, 07-28-2020 05:47 PM
    output, power, supply, tube, voltage
    07-29-2020, 04:45 PM Go to last post
  15. Replacement Controller
    Started by Legonerd, 03-17-2020 06:10 AM
    07-02-2020, 02:52 AM Go to last post
    06-23-2020, 04:07 AM Go to last post
  16. 40w laser tube lower voltage connector burn mark
    Started by NaN, 05-13-2020 12:17 PM
    05-13-2020, 12:17 PM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
