587,442 active members*
3,101 visitors online*
    Mar 2018
    4
    laser firing when traveling to origin
    Hi. I just change controllers and the laser is firing when traveling to its origin. It happens when I turn on the machine and when its finished cutting a job. It also wont fire at 21% but is full power at 22%. It did that with the last controller as well. Any ideas
    \Thanks
    Jan 2012
    43
    Re: laser firing when traveling to origin
    what controller are you using and software?
    Apr 2006
    108
    Hello,
    I have seen this a few times...
    The problem is much more likely to be in the logic portion of your laser power supply. The best and safest way to solve the problem is to replace the laser power supply.
    It all depends on how the controller and laser power supply are wired... but you should confirm the wires from Laser-On are connected to theL pin of the power supply. Then make sure the software is configured for Low signal triggering.
    Make sure the Analog signal is connected from the controller AN1 to the “IN” pin of the laser power supply.
    Please take time to tell us what solved the problems.
    Ray Scott
    Rabbit Laser USA
  1. gcc c180 laser engraver problem .. laser tube firing a continuous weak beam
    By badrawy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-27-2020, 01:41 AM
  2. Laser wont stop firing while traveling to and from home
    By Nate33 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-17-2018, 01:16 AM
  3. China laser started firing laser during rapid moves
    By Billn in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-21-2016, 06:32 AM
  4. Need help on Laser Firing in China Made laser Cutting Machine
    By doken in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-16-2015, 04:11 PM
  5. Laser engraving machine not firing laser from software or controller.
    By JustTruckinng in forum Engraving Machines
    Last Post: 05-14-2014, 04:14 AM
