587,426 active members*
4,280 visitors online*
Results 1 to 6 of 6
    Jan 2014
    2
    Laser engraving with CamBam/Mach3
    Is there a forum out there of folks using CamBam/Mach3 for laser engraving? Specifically, I'm trying to figure out how to get the laser to engrave the insides of the fonts as well as the outline. Maybe this is too dumb a question, but any help would be appreciated.
    Jan 2012
    53
    I'm not sure there's a forum for exactly that, but I use this setup. You could try creating a polyline outline of the letters and persuading CamBam to do a pocket operation with the tool diameter set to the laser kerf (about 0.2mm for me). I think there are some hatch operations that might work too.
    There's also a Mach3 plugin for raster engraving that might work for you. One limit of using Mach3 is that raster stuff is harder.
    I'd suggest looking for more info on the Mach3 and CamBam forums.
    Nov 2008
    643
    The result of the Cambam pocket operation really isn't a raster type cut. its really a series of vector cuts equal to the stepover amount. You need to specify a beam diameter and play with the stepover. I would think this cut would require considerable cleanup to remove all the burnt wood. Unless you want that dark color. Attachment 218890
    Jan 2012
    53
    Dean's right. It's not ideal. The horizontal hatching (or something like that - I've not for CamBam in front of me) also isn't perfect but might be better.
    Jan 2014
    2
    Thanks guys I'll give it a try. I'm brand new to all this.
    Oct 2008
    34
    mach can't do that perfect, if u do that work as pocket engraving u'll encounter these:
    - job time very long
    - engrave lines at two ends of each horizontal line will be deeper (acceleration limits)
    - bec of mach's optimization of movements ("constant velocity mode) engrave lines will be crooked at ends (also all mechanical looses show their effect such)
    it's better to use corel or softs to fill shapes wit horizontal lines and do that in vector cutting mode (crooked lines will be better)
    i think mach3 engraving plugin just works with bmp not vectors.
  1. Help, new to cambam, mach3 . . . .
    By jmf in forum CamBam
    Last Post: 05-29-2013, 07:15 AM
  2. CamBam engraving problem
    By jakuba in forum CamBam
    Last Post: 11-06-2012, 07:55 AM
  3. Need a bit of help on first cut CAMBAM,Mach3
    By idtat in forum Community Club House
    Last Post: 02-26-2012, 05:10 PM
  4. Engraving Trigger for Laser or Impact (Mach3)
    By Pierke in forum Mach Wizards, Macros, & Addons
    Last Post: 07-25-2009, 06:43 PM
  5. Engraving/Milling with CamBam
    By GeorgeRace in forum CamBam
    Last Post: 06-27-2009, 08:24 PM
