587,442 active members*
2,978 visitors online*
Results 1 to 7 of 7
    Mar 2015
    6
    Laser Engraved Text Looks Jagged
    Hey guys,
    So just this past week I have noticed the text that I engrave is not so sharp looking anymore, it has a jagged look to it.
    I've cleaned the machine out and oiled it but still I get this problem. Up until a few days ago this problem did not occur though.
    Any ideas what could be the problem causing this?
    Sep 2014
    128
    Re: Laser Engraved Text Looks Jagged
    Loose lens?
    Mar 2015
    6
    I've checked the lens and everything looks alright, fits the same as it always did.
    Just did another top to bottom clean and oil and yet the problem persists. I have noticed the "wonky-ness" of the text varies on each test I do so its not like it is happening the same way in the spot each time. I will post some pics if I can later to show you guys what I mean.
    Mar 2015
    6
    Mar 2015
    11
    Can not see this pic clear.
    I suggest you try this.
    1. check you rail, belt are those that smooth. clean rail and drop some oil.
    2. check and clean your 1 lens 3 mirrors, make it perfect.
    3. try to uninstall your laser software and reinstall it.
    4. go to your software "setting" or "Advanced Settings", then go to "engraving" setting. Somewhere you will find "Backlash" or some other statement like this. Change the values more or less, try engraving again.
    What is your software?
    Wish your machine work fine soon.
    Justin
    A nice guy!
    Mar 2015
    6
    I think I may have found the problem. My rail is beginning to look worn where the bearings have been rolling over it often, the paint has come off and when I run my finger over it there is a slight groove. I notice that when rolling the bearings back and forth slowly by hand that they do not roll so well over this part of the rail. I tested engraving some text on scrap material and different points on the rail and noticed that the far sides it performs fine, it is when the engraving passes the mid point where the worn area is that I get jagged lines and text.
    So does this seem like the plausible root of the problem here? If so how difficult is it to replace this part of the machine?
    Mar 2015
    11
    Quote Originally Posted by II-DALTON-II View Post
    It is not difficult to replace it. Make sure every screw holes tight and keep sliding block very smooth!! You can ask for a help from your supplier.
    A nice guy!
  1. streaks on laser engraved image
    By identilase in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-29-2011, 08:37 AM
  2. Laser engraved bricks and limestone???
    By aocarving in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-01-2010, 04:25 PM
  3. Pewter - can it be Laser engraved?
    By bubbs64 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-17-2010, 11:55 AM
  4. Painting engraved text
    By Photon713 in forum Material Machining Solutions
    Last Post: 07-15-2009, 01:12 AM
  5. Can I use Alibre Express to design a part with engraved text?
    By Evolution VIII in forum Uncategorised CAD Discussion
    Last Post: 06-04-2007, 09:58 PM
