587,404 active members*
3,374 visitors online*
IndustryArena Forum > Community Club House > Laser cutting Problems DROSS
Results 1 to 2 of 2
    Aug 2013
    0
    Hello everyone,
    i am using a bystronic laser cutter. i have been told that for cutting thicker mid steel oxygen pressure should be reduced.
    whenever i reduce the pressure i can get a good cut on the outer profile of the part by any smaller holes and slots are very drossy. i can overcome this by setting my press higher for example im cutting 8mm mild steel with 1 bar of oxygen press which just seems to high..
    Any help welcome,
    Thanks,
    David
    Hey dude! I also want a welder or cutter who welds and cuts the steel plates for my construction project and If you have any person related to this field then contact me please.....
    steel fabricators Mackay
  1. problems on Trumpf laser cutting machine
    By arnoldino in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-03-2015, 04:17 PM
  2. Need high quality dross on Plasma cutting
    By yeye in forum Waterjet General Topics
    Last Post: 02-08-2012, 02:07 PM
  3. Replies: 0
    Last Post: 10-17-2008, 04:17 PM
