586,516 active members*
3,862 visitors online*
IndustryArena Forum: Kitamura
Page 3 of 13 12345
Threads 41 to 60 of 245
Discuss Kitamura CNC machines here.
  1. 86 Kit Mycenter 1 wrong tool in spindle
    Started by JolietJames, 01-30-2020 04:02 AM
    change, couple, info, machine, tool
    01-30-2020, 04:02 AM Go to last post
  2. ''Not Ready '' Kitamura Mycenter 2 Fanuc 6m
    Started by Caees, 01-28-2020 01:14 PM
    fanuc 6m, kitamura, machine, mycenter, not ready
    01-29-2020, 12:24 AM Go to last post
  3. Unhappy Trouble Setting parameters Yasnac I80
    Started by agood01, 07-14-2011 04:35 PM
    bat, battery, color, control, email, india, kindly, lost, machine, not, option, option parameters, parameters, run, send, set, setting, silver, size, then, trouble, vmc, yasnac, yasnac i80, yasnac i80m
    12-28-2019, 03:03 PM Go to last post
  4. Y-axis lock Kitamura Mycenter 1B Fanuc0M 1986
    Started by onkelbaers, 11-28-2019 11:18 AM
    kitamura mycenter fanuc, ladder, machine, time, y-axis
    12-12-2019, 04:33 PM Go to last post
  5. 86 mc1 10M Drip Feed issue
    Started by JolietJames, 12-07-2019 03:27 PM
    dnc, drip, machine, program, software
    12-08-2019, 07:13 PM Go to last post
  6. Kitamura mycenter 0 head scratcher - tech help?
    Started by DaOne, 08-30-2019 10:06 AM
    bit, flipping, random, relay, time
    08-31-2019, 05:55 AM Go to last post
  7. Kitamura Minisuper 300 Retrofit - Part2
    Started by seahawkibiza, 08-01-2019 05:57 PM
    kitamura, minisuper, part2, retrofit
    08-20-2019, 11:51 AM Go to last post
  8. Fanuc 6M Origin Resets with Reset Key
    Started by legacymachining, 07-23-2019 12:27 AM
    machine, return, set, time, tormach
    07-23-2019, 12:27 AM Go to last post
  9. Mycenter 4 Spindle Air Oil issue 16i-M
    Started by MBX5, 12-30-2016 05:31 AM
    cnc, issue, reset, software, unit
    07-11-2019, 02:54 PM Go to last post
    07-01-2019, 04:23 PM Go to last post
  10. Disable 4th and 5th Axis
    Started by IrishJ, 03-11-2019 01:38 PM
    4th, 5th, axis, disable, turn
    06-29-2019, 03:15 AM Go to last post
  11. H300 B axis rotation speed
    Started by stude8, 06-24-2019 03:07 PM
    axis, changing, pallet, rotation, speed
    06-24-2019, 03:07 PM Go to last post
  12. Kit tool changer arm stuck in mid stroke
    Started by new2kit, 08-24-2010 01:39 PM
    another
    05-27-2019, 10:50 PM Go to last post
  13. MyCenter 1
    Started by robokd, 05-08-2019 05:09 PM
    backup, happen, memory, mycenter, parameter
    05-08-2019, 05:09 PM Go to last post
  14. Reset turret position for KNC250YS
    Started by sting007, 03-12-2019 07:01 PM
    home, knc, position, reset, turret
    03-12-2019, 07:01 PM Go to last post
  15. Kitamura Minisuper 300 Retrofit
    Started by seahawkibiza, 03-12-2019 02:08 PM
    beamicon2, kitamura, machine, parts, retrofit
    03-12-2019, 03:46 PM Go to last post
  16. kitamura mycenter 3x opions
    Started by msherman, 03-07-2019 03:11 AM
    check, cnc, kitamura, machinist, years
    03-07-2019, 03:11 AM Go to last post
  17. Mycenter 1 Toolchange Problems
    Started by Hurco Matt, 11-22-2017 09:00 PM
    carousel, mycenter, rotates, spindle, tool
    11-27-2018, 09:21 AM Go to last post
  18. Kitamura Mycenter H400 - tool clamp issue
    Started by shas595, 11-17-2016 12:48 PM
    change, clamp, spindle, tool, unclamp
    11-27-2018, 07:27 AM Go to last post
  19. Manuals Kitamura mycenter 4 1990
    Started by richardfp4, 10-01-2017 07:56 PM
    controll, fanuc, kitamura, manual, manuals
    11-27-2018, 07:13 AM Go to last post
Page 3 of 13 12345
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
