Hello.
I have a Yaskawa V7 VFD, and I want to use for the spindle motor control for my Bostomatic CNC Mill retrofit.
I already have it wired and it works great, but the speed is controlled manually using the front panel pot.
But now I want to control it within the software using Kflop.
This drive has a lot of options to control, acording to the manual this are the options:
Attachment 238104
I know a easy and quick way to control is using 0-10v using Kanalog and a DAC output.
I already bought a Kanalog, but using it only for the speed control of the spindle is too much.
So that is why I want to control the VFD using the "Pulse train command control input (option 5 acording to the manual)"
I read all the manual and I could not find to much information about this option.
This is what I think is all the relevant information about this control option.
Attachment 238106
According with this information and my basic knowledge of electronics, I can't figure if this "pusle train" is compatible and the Kflop is capable of handling that kind of signal.
So, my questions are:
The Kflop can generate a signal compatible with this pulse train input of the VFD?.
According with the characteristics of this pulse train, do you think this is a PWM signal or maybe is more like a Step-Dir pulse train?
Any help would be greatly apreciated. Thank you very much in advance.
By the way, this is the Product Webpage and it have all the manuals, just in case you can find something else which can be helpful.
V7 Drive
