Greetings all,
I am setting up my X2 with a tooling plate to use with Hoss's tool touch probe. I have isolated a 4x4" steel plate on plastic strips and wrapped t-nuts in plastic too. it works well, but when coolant floods the table and t-nuts, my tooling plate is no longer isolated.
I was thinking of adding a resistor inline with the touch probe signal wire, but not sure if this is the right approach. I am running Mach3 with a G540. I have the machine grounded and the tooling plate is the signal.
Any thought appreciated!
-Kevin
