587,434 active members*
3,413 visitors online*
Results 1 to 6 of 6
    Apr 2012
    82
    Is there a way to speed up my weike 1290?
    I guess I have been spoiled by using the epilog lasers.. Im running a rather small engraving that only takes about 4 minutes on the epilog but the same job takes around 15 minutes on the weike....
    That is over 3 times as long.. The weike machine is also equiped with an 80 watt tube compared to the epilog which has a 60w tube...
    Any and all suggestions are more than welcome.
    Apr 2012
    82
    Ok I think I just figured out one problem... I had my scan gap set way to low.. Was at .01 which is apparantly way over 1000 DPI.... Ill try a scan gap of .1 tomorrow and see if that helps the cause.
    Jan 2011
    242
    Changing the scan gap will make a huge difference. 1000dpi vs 500dpi will result in the engraving taking twice as long. At .01 scan gap, you were engraving at 2540dpi. Dropping down to 500dpi you should see engraving speeds drop from 15 minutes to 3-4 minutes.
    25.4/DPI = Scan Gap
    DPI = 25.4/Scan Gap
    Feb 2005
    469
    For future reference..
    DPI = Scangap
    1200 = 0.02116
    800 = 0.03175
    600 = 0.04233
    500 = 0.05080
    400 = 0.06350
    300 = 0.0846
    200 = 0.12700
    150 = 0.1693
    100 = 0.2540
    Scan gaps smaller than the physical beam size are pointless, all you will do is run over the same stuff time and time again
    The only exception is when grade engraving
    best wishes
    Dave
    Apr 2012
    82
    Its all much better now.. I misread the settings.. It works great now that I have the proper settings.. Thanks for all your responses!
  1. New setup for GWeike 1290, Couple of questions,
    By ffokazak in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-04-2013, 12:40 AM
  2. Gweike 1290 Laser
    By Gweikelasers in forum News Announcements
    Last Post: 11-14-2012, 03:03 PM
  3. G.WEIKE NEW AUTOFOCUS
    By gweikelaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-21-2012, 01:33 AM
  4. Jiachen 1290 Driver
    By mnajera in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-13-2010, 11:35 PM
  5. Help MPC6515 (JCUT-1290)
    By suyoothi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-09-2009, 07:14 PM
