586,032 active members*
2,972 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Is there a way to oversize the table of a chinese laser 50W 50 x 30 in 5mm?
Results 1 to 4 of 4
    Apr 2006
    38
    I know that what i'm asking is very unusual, but let me try to explain.
    I have a cheap chinese laser 50W with 50 x 30 cms cutting area, and it works like a charm for 2 years without any problem, sometimes 8 hours a day for 5 days a week, believe it or not.
    One client ask me to cut a piece of 502.6mm wide, so as you image does not cut on the table that cuts only 500mm.
    If I can adjust the setup to 503mm x 300mm i will be able to cut this file and keep the client........
    I use Laserworks 6.00.44 software and try to change settings to "cheat the machine" in 3 or 4 mm. In the machine there is enough space for it.
    In the software there is a page setting that I already did the change, but still not accepting and the machine control panel says "SLOP OVER"
    Is there a way to increase this area in 3 or 4mm?
    I appreciate any help or idea.
    Here is my machine model
    Attachment 270308
    Jan 2008
    940
    Re: Is there a way to oversize the table of a chinese laser 50W 50 x 30 in 5mm?
    Go into to vender settings and adjust the Breadth setting for each the x and the y I have mine set to 525 X and 325 Y that gives me almost an inch each way On mine the vender password is RD8888
    Apr 2006
    38
    Fixtureman1,
    YOU ARE THE MAN!!!!!!!!!
    Problem Solved.
    Thank You, Thank you and Thank You, you save my day!
    :banana::banana::banana::banana::banana:
    Rick Santos
    www.co2br.com
    Jan 2015
    23
    thanks fixtureman1, great tip!
  1. Chinese laser question stronger at top of the table vs bottom
    By turbojamie in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-06-2014, 04:06 AM
  2. Optional Acessories Introduction of GWEIKE LASER / CHINESE LASER
    By Gweikelasers in forum News Announcements
    Last Post: 08-15-2013, 02:52 PM
  3. X3 Cutting Oversize
    By mikemill in forum Syil Products
    Last Post: 05-10-2013, 08:23 PM
  4. Add US made laser module to Chinese laser?
    By glintid in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-02-2012, 08:43 AM
  5. Optional Acessories Introduction of GWEIKE LASER / CHINESE LASER
    By Melody-gweike in forum News Announcements
    Last Post: 04-14-2012, 02:37 PM
