587,171 active members*
2,898 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > USA Club House > Is it posable.... to use a g13 to cut a circle on the y and z axis?
Results 1 to 2 of 2
    Aug 2014
    1
    Hi, im trying to program some internal de burring of a part we make at work. In most cases i can get away with useing a G13 to cut a circle around whatever intersection i am trying to deburr. In this case i can not reach inside the part and use a G13 the way i normally would. Im already inside of a bore and inside this bore i am trying to deburr a .125 dia hole at a 56 degree angle. What id like to know is can i use a g13 to deburr the feature useing the y and z axis. Is this posable? If i sound stupid Sorry im just trying to learn new things. I dont get the opertunity here at work to use mastercam17. Otherwise id be drawing it and doing it that way.
    Jul 2014
    18
    Re: Is it posable.... to use a g13 to cut a circle on the y and z axis?
    I am only aware of G13 in G17 plane selection. The surface at 56° does not lie in A work plane. Otherwise you could G03 with IJ or K to swing the arc (G18 G19). I have only done what you are asking with a 3D contour from a CAM package.
  1. Draw line tangent from small circle to large circle
    By WEDDLETON in forum ViaCad / Shark
    Last Post: 07-30-2014, 05:53 AM
  2. Replies: 16
    Last Post: 02-05-2014, 08:21 PM
  3. Making a 38mm D circle stalls X axis motor
    By cletero in forum G-Code Programing
    Last Post: 11-21-2012, 02:52 PM
  4. write gcode for circle with 4 small circle inside it
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 12-13-2010, 05:24 PM
  5. Is this posable
    By rk176 in forum Diemaking / Diecutting
    Last Post: 05-27-2008, 04:52 PM
