We cut black acrylic 1/4" to hide 80mm cooling fans. I have attached a pdf of what it should look like and inserted a picture of what the machine is cutting now.
The fans used to cut fine as long as we exploded them in AutoCad. We checked alignment of the machine including the axis and we are fine. The only thing we have done is to replace the drive belts. We have a 4x8 bed. I have tried using old files and we get the same problem. I rebooted my machine to see if Lasercut 5.3 was corrupted.
I can only think of two more things to try...
Re install laser-cut
or re-install firmware on the controller we have a the 6535
I am open to any an all ideas on what is causing this.Attachment 185078
Thanks all
Tom
