Hello ,
iam facing a problem in the sheet metal flat pattern lines , when saving the flat pattern as a DXF all center lines (representing bend lines) are converted to continuous lines which cause a problem that my CNC bend machine software can not read the bend lines as a continuous line .
So is there any way to enable the saving of center lines when exporting the DXF file from the flat pattern
