I would appreciate the g214 and use it on the indexer
I sincerely apologize for not having responded sooner. I've been 'on the road' on client projects for a month, and not able to address this.
I received my G214 drive while away, and have just unpackaged it. It looks robust and has screw-terminal terminations in addition to what's shown in the video. It also has a robust heat-sink, which is obviously intended to be further doped and attached to a larger heat-sinking surface.
I'm slightly confused, in that I cannot see any reference to part # 214 on it: in fact, the only number I see that looks like a part number reads "050216". The parts-layout is identical to what is in the vid, except for the screw-terminals (which I much appreciate).
It will be still be a while before I can try this on the machine I mentioned in the contest, but I just spent the last two weeks on that site, and it would be VERY beneficial to their productivity, if this drive will alleviate the resonances they have in one component of it.
Thanks SO MUCH to Gecko for giving me the opportunity to evaluate this. Every other drive in that machine is Gecko, also... so you can tell I'm 'hooked' on their products!
Lloyd
Lloyd,
Thanks for the response! The numbers on there are a revision number (just a date code) and the "Kirzaka" is the internal project number. All of our projects get internal nicknames, like the GM215 was Bihu, and sometimes they make it on to the PCB. Some of our customers private label stuff so we can't usually have any part numbers or logos on the bare PCB, especially with an open frame drive like this. We are most likely going to put a cover on these and are working out the design of them but the connectors on either side make it a bit difficult. I've attached a rendering of what a potential cover will look like in the future.
Attachment 332778
Marcus Freimanis
www.geckodrive.com
SteveS,
Go ahead and shoot me an email at [email protected]. We can get you a couple G214s sent out free of charge. That sucks that the private messages didn't go through, but you're here now so that works out.
Marcus Freimanis
www.geckodrive.com
Thanks Marcus to the rescue.
I just don't know how to respond to the message and I don't want to let go of the Gecko drive
Haha don't worry about it. There was a problem on the backend of CNC Zone with private messages so we now have five winners instead of four. More G214s for everyone!
Marcus Freimanis
www.geckodrive.com
