587,322 active members*
3,354 visitors online*
Page 1 of 2 12
Results 1 to 20 of 34
    Sep 2007
    26
    Integrated CAM Advantages?
    I've been in this industry for 20 years, and this experience has convinced me that the future of CAD/CAM lies in Integrated solutions. By Integrated CAM, I mean CAD/CAM software that runs inside of mainstream CAD systems like SolidWorks or Inventor.
    I compiled a list of advantages on my company site:
    http://www.ngms.us/integratedcam/integratedcam.htm
    I'm sure there are others advantages I've missed.
    Some of these advantages are compelling on their own; like eliminating data translation errors.
    But I am also finding that some work to help and reinforce the others. That is, Integrated CAM opens the possibility of new ways to approach machine tool programming. There are synergies at work that seem quite powerful.
    A simple example: SolidWorks supports Assemblies and configurations, and with an Integrated CAM system, you always have access to the design tree (which you can loose with stand-alone systems during the conversion process).
    Now I find myself making different configurations of the part for different phases of CNC machining. My first configuration might have many of the features suppressed and show all the clamps as part of an assembly. Later, I might only show cavity features, but with holes or features to be drilled or burned suppressed in the design tree (rather than capping surfaces like we did in the old days).
    Obviously, I am a believer in Integrated Systems, and have a commercial interest in them. And one sure way to start a flame-fest is to talk about the advantages of this brand CAM over another.
    So, I'd like to discuss this on a more academic level, and try not to talk about specific products.
    The question is, how do you see the advantages or disadvantages of Integrated CAM, and how have you used CAD functions in mainstream CAD (Solidworks, Inventor, PTC) to prepare a part for toolpaths?
    Sep 2006
    136
    Agree totally. At present, I model in Inventor and then take the modelled part into Edgecam which, despite claims to the contrary, does not support solid models terribly well. (It seems to extract surfaces from the solid and works with them instead). If the designer has left off features like chamfers or fillet edges, I can't machine them. (well, not easily anyway)
    A ridiuclous way to work really. To be able to do the whole design to manufacture process in a single app. would be the perfect way to work. I do wonder why Autodesk don't offer a CAM product.
    Aug 2006
    77
    Cool
    I've worked in 2 programs have integrated solutions, There are a number of benefits to working in a native enviroment, for once you can better see the design intent of a part and as you pointed out the ability to either hide or suppress features is a great plus for model manipulations. I dont work with a integrated solution right now due to a few shortcomings and lack of support in my neck of the woods for a certain cam add-in. I am using Esprit and Solidworks and while Esprit does not work directly inside solidworks you can import the native model and the design tree as well so Im happy. One caviat worth mentioning, Im sure in 20 years you've seen a lot of thing and I think you would agree that regardless of what cam software you've used the biggest hurdle to over it's not the integration of the cad/cam software per se, but a well built model and a builder that has some practical knowledge of manufacturing, too often have I seen models were the only reason for having a radius on every single edge a part has it's because it looks nice regardless of how complex or cost productive it may make the part....LOL Just my two cents.
    CAD/CAM
    How can a CAM package be truly integrated when you are installing a package from another vendor?
    To be truly integrated the CAM solution must run inside the CAD as you say. This is the only way it can work seamlessly.
    When CAD packages make a change to how they interact with their kernel they happen to be using what other affects does this have? How long will it take the "certified partner" to find this new undocumented feature? How long will it take the development team to fix the software to correct the error?
    As many will point out on this topic the so called "certified partners" are not always 100%. How can they be when it is a separate install to get CAM?
    There is a translation going on in the background to get the info to the CAM side. These cam engines really choke on imported files that have poor geometry.
    Just my $.02
    GreatLakes3D
    Jan 2006
    204
    I am a total newbe so don't kick me too hard. Is this not what featurecam does or am I missing something.
    archie =) =) =)
    Jan 2007
    197
    i agree and would like to add to the idea: I would like to see the electronics side integrated into the m-cad side and then integrate the cam handling too. I have to do design of both electronics and mechanical parts to design my systems, and I think it is nuts that i have to run 3 different programs to get from electronics to mech to cam. the interconnect between solidworks, inventor, Pro/E, etc to programs like orcad is getting getting better, but its still about a good as the cad to cam interface is now.
    i also agree that good designs start with designers who know how to fabricate things. since i started looking into cnc, i have modified my design habbits so that they can actually be machine without some obscene tooling set up.
    -Jeff
    May 2008
    2
    Quote Originally Posted by NexGenMfg View Post
    I'm new to the CNC world, working in the wood products side, and I've been shown a really sweet program called "Top Solid" that does just what you're talking about. It is produced by the Missler company out of France, and in the rest of the world, it is well known; they have yet to really reach the American market.
    I've seen it working first hand running a thermwood CNC router, and the time it took to send the drawing to the router and start milling was hardly enough time to let your coffee even start to think about cooling down.
    Jan 2007
    197
    wow! sounds cool.
    -Jeff
    Dec 2006
    20
    Nio choice
    We are doing free form shapes and trying various iterations and letting people handle them. Just about impossible to program by hand. Intergration with the design software is just common, lean sense. Less one handles complicated models the less mistakes can be made. Bit of a no brainer.
    Feb 2008
    2
    Are you desigining your models?
    The problem with Integrated CAM occurs not when you have control of the whole design cycle. If you're machining your own parts and designs, it's IMHO better to have it all integrated, being a user of Pro/E and Pro/NC, I see the many advantages of it.
    If there's true associativity and a good NC package, you can do a lot. Using Pro/NC I used to see many disadvantages against Standalone CAM packages, as Pro/NC was outdated and felt like a last minute, second thought module. In the last few releases they put Pro/NC higher on the relevance list and we saw MANY upgrades for it, now they've included a good module based on a Standalone Program and have done a somewhat good integration (probably much improved in future releases).
    This happens with many other Integrated CAM packages. Wether it be problems with Integration or just a secondary module without all the power of the Bigger Standalone packages. Associativity is a great thing to have, but many of the bigger packages offer this to some extent.
    The difference is noted when your customer gives you a digital model. Standalone CAM systems rely on data import and so, they have really good methods and are optimized to work with different source models.
    Now there are many tools (Import Data Doctor, on Pro/E for example) that help you import models and then you somewhat mantain the integrated advantage: you can use Machining assemblies for the setups, and now many of the bigger players (NX and Wildfire 4) have added good feature recognition and control for imported geometry. But then again it comes to how well your main package handles imported data, which on some of the midlevel packages, my experience have ranged to acceptable to outright disastrous on some cases. (Of course it also depends on the source data).
    So if you're a production company, Integrated is the way to go, wether it be an integrated associative external package or an In house developed solution, you'll find advantages and disadvantages to each and have to evaluate each package on it's own and on your field/way of work.
    Now, if you're a contract machining shop and machine parts from lots of different sources, not always modeled by your people, then the panorama is not as black and white. There are many advantages to Standalone CAM packages that you MUST evaluate. Also you have to analyze, if the data import module of your Integrated system is up to the task of receiving ANYTHING you throw at it. (As most of the standalone CAM packages excel at data import).
    Having worked at a Mold making shop, can see the advantage of an Integrated package, which is good with imports, as you sometimes need to import a part model, and then design the mold around it. Or sometimes you need to use a great modelling system to design complex plastic parts.
    Another experience in a JobShop, teached me that standalone CAM packages are way better at tackling parts for machining and being developed around machining an imported part, you can see how the workflow is much better for that type of work.
    just my two cents.
    Mar 2006
    1013
    If your using Solidworks and something else, it's not really an integrated package. Cad systems that offer Cam as an option are truly integrated. The problem with that is... Most Cad packages offer poor Cam applications.
    Edgecam does a good job of reading the Solidworks/Inventor files and creating toolpath. The problem is that their ability to create toolpaths from the model might be limited to the "features" it finds, or that the user defines. Great for prismatic blocks, but not for open ended shapes with lots of boss's.
    Mastercam is an integrated CadCam package. Their Cad is pretty good. They offer Parasolid modeling and their toolpaths are very strong. Of course Mastercam Solids does not have the power that SWorks/Inventor have for modeling.
    But as a machinist, you need to consider the package that lets you get the best toolpaths, with the most control. Mastercam will read Sworks and Inventor files without any additional cost. It does a good job of importing other formats also. They have a new function called "Change Recognition" which will tell you what has changed on a modified model. Very nice tool.
    Mastercam is due to come out with a package that will run inside of Solidworks. They might be worth looking at when it's available. Powerful toolpath control right in the Solidworks environment.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Apr 2005
    80
    I like the CAM in Catia. I like to get down to the nuts and bolts of programming and Catia will let you and also allows you to highly automate.
    It will handle pretty much anything you can throw at it.
    I tooled a Point cloud to vector surface with 47000 surfaces no problem!
    Tried the same model in Master Cam and Surf Cam and they ran out of memory.
    I have used CAM in ProE and NX and both are pretty cumbersome and non intuitive "legacy from there Cad environment". ProE Cam just seemed to limited while NX is a lot more robust it still falls short of Catia.
    I have demoed Inventor Cam and Solid Cam a while ago and was pretty disappointed with its ability's and functionality. I think the integration is just not what it needs to be yet.
    Integrated cam has the advantage of utilizing the more advanced mathematical algorithms in these higher end Cad programs. Witch in turn not only adds ability but speed and precision in compilation of complex surfacing tool paths.
    While some stand alone CAM are pretty good they all fall short of the power harnessed by the many years the major Cad programs have chiseled into there backbones.
    The one thing stand alone CAM has over Integrated is a broader selection. Although most are highly over priced with what they offer. There are a few that are a more cost effective solution if you don't need to be opportunistic?
    Feb 2008
    2
    You nailed! That's exactly my point. It depends, MasterCAM is great at importing from whatever source you need. A CAM oriented package, for what I see.
    I don't consider MasterCAM an Integrated Package anymore than EdgeCAM or PowerMill could be. They're designed with CAM in mind and offer very basic Design options, many people design surfaces on MasterCAM, however having done that, you can see that clearly their focus is on model import and basic modifications to the design, now starting with some solidmodeling, again focused on setups and basic shapes.
    I remember using Mechanical Desktop (!) to model parts and Edgecam opened inside Mechanical desktop, adding just toolbars and menus. Totally associative. That would be a sweet in between point, which I think they're doing in many of the midlevel packages now. EdgeCAM is associative to Pro/E which is a good thing to have.
    Based on the increasingly difficult differenciation between "integrated packages" (single source?) "Standalone CAM centric Packages", "Integrated Add-on modules", etc. (Even the thread starter is not referring a Single-source integrated software package, as they "integrate" into many existing modellers), should the question be rephrased as:
    Should Associativity between your design model and machining model the main focus of the selection?
    There seems to be somewhat of a compromise between good associativity and good multisource data import. Given the complexity of the modelling and variety of modelling kernels, it doesn't come as a surprise; as the more integration you accomplish, the more you tie yourself to one or a few of the modelling kernels.
    Given the many different workflows and types of industry, scope of shops, there won't ever be a single answer to this question, as it depends too much of which factors weigh more for a determined machining company.
    Are they important to note? I would put them right on top of the list, right next to machining strategies and ease of use. Either if I was to give more importance to Integration (Associativity) or Data import capabilities.
    May 2006
    803
    Engineering vs Manufacturing vs total integration
    Engineering vs Manufacturing,vs total integration
    Two separate disciplines, thought processes and problem sets.
    This was the same question in the mid 80's when we were developing
    cad cam on mainframe systems. (major Aerospace company)
    ((by the way I saw my first computer graphics in 1968))
    The first N/C machining and CAD system was done in a high-level Fortran system, hand coded on punched cards and tape. 100% parametric.
    It brought us such things as the Space Shuttle.
    Back to the future now.
    Engineering defined their geometry as the end part.
    Manufacturing defined their geometry as needed to get to the final part.
    We (Cam) used their geometry to build from (roughing).
    Cam used the same geometry system to build from to keep the integration.
    Our systems programmers used the cad internally to compute toolpaths.
    It worked and we built multi-axis very complicated parts.
    In 3-D black and white wireframe representation,
    Long before the days of PC's, workstations, Windows, etc.
    Here is How I define this continuing dilemma. nothing new now
    Geometry is geometry. math is math. Old stuff unchanged in years,
    a line is a line, (check the analytic geom, check the formulas)
    a circle is a circle , etc. arc is a subset of circle. on and on.
    The problem is is how this is stored in the respective database.
    And retrieved for display to the user.
    So we now have a zillion Cad systems because every system programmer designs their database differently.
    System programmers are neither engineers nor machinists.
    They all want / need jobs so everyone re-invented the same old wheel.
    Wheel = Circle = anything new yet?
    Everybody thinks their way is the "best" "only" way, I can do it better.
    They attempted geometry standardization first with I.G.E.S. (late 80's)
    Then the powers (engineering ran the show) did not want to
    "get their hands dirty" with the manufacturing data.
    Engineers did not understand our (cam) needs so they just
    rolled over and abandoned the mfg side of their job.
    "You guys just build it. we have too many other things to do."
    Just remember that engineering as a profession came from
    the machine shop waaay in the past. We have all specialized now, remember Thomas Edison, and other prominent inventors of history were machinists.
    SO whatever system you use for cad cam there will be compromises to be made. The perfect system does not exist. There are some fantastic specialized machining algorithms to purchase, Machine shops have their specialties, one size does not fit all. Pretty renderings do not make parts, machinists do.
    Remember the Burger King motto "Hate it Your Way" but get the job done and get paid.
    Been doing this too long
    Sep 2007
    26
    Apache405: Didn't I read somewhere that SolidWorks had purchased CircuitWorks?
    Jeep534: By Integrated CAM, I mean a CAM system that runs in a single-window environment of a mainstream CAD system and that do not translate the data to a different fromat (toolpaths saved as part of the native file) as with SolidWorks Certified Gold partners.
    I think of ProE/ProMan, Catia, UG, etc. as "all-in-one" systems, because both CAD and CAM are developed by the same company.
    Like Mike Mattera said, the problem with some of the "all-in-one" systems in the past is that the CAM side was lacking. I think this was because most of the company resources were poured into the CAD part of the software, because that's what drove sales and produced the more revenue. That may have changed some, but I am not familar with recent versions of any of the all-in-one systems.
    I consider Integrated CAM a new class of software. It is created by a separate company, and shares the same database and user interface as the CAD system, eliminates data translations (if running in the native CAD) and is fully associative with the model.
    Being developed by a separate company has its advantages. A SolidWorks or Autodesk created CAM product might suffer the same as the old all-in-one systems. A 3rd party devoted to CAM would probably be more focused and proficient in creating toolpaths.
    Apr 2005
    80
    Quote Originally Posted by bostosh View Post
    There are still people around like this.
    Basically I cant imagine being an engineer that doesn't know how to manufacture. The two are one in the same "for me anyway". I guess it might just be my compulsive curiosity of everything. Or maybe it is just my view point because I worked my way from the bottom up.
    What I was saying about more advanced math is that the equations used are more refined "tuned for speed". For example the use of vector calculus compared to standard trigonometry. Yes in the real world arcs are arcs and lines are lines but in programming there are many ways to go about creating them, displaying them and manipulating them. Nothing is good enough ever!
    Speed is a ratio of time and money. Ability is the capacity to acquire it. And Imagination is the creation of it.
    Apr 2006
    130
    There are some comments about how CAD and CAM can be integrated if from different vendors. The best answer is take a look. Ask questions like ... one database, or copy? working on entities, or faces from solid? reaction to model changes, etc?
    Other comments have said that certain evaluations have shown poor CAM performance. This is not a function of integration, but a function of poor CAM performance.
    Another point, consider to have CAD supplied by a CAD specialist, and CAM by a CAM specialist. If the integration is complete (please check), then you have the real deal.
    Tomorrow, I fly on a plane made by Boeing and an engine made by GE (or Pratt and Whitney), and I'm OK with that. Is this an integrated solution??
    Apr 2005
    80
    Quote Originally Posted by Alan L View Post
    I know I shouldn't post such a worthless post but I gotta say it
    They both use Catia! :idea:
    Apr 2006
    130
    To add some clarity to bsharp's post, and without divulging too much of the inner workings of [unrelated] engine companies, let's say that CATIA is used in one Pratt plant, but otherwise these engine companies use a different CAD/CAM, and often additional software tools beyond that.
    Major companies view major CAD/CAM and integration differently than the remaining 2/3 of the manufacturing workforce - no opinion added.
    Aug 2007
    5
    i work with cnc mill for about 5 years, first started with Solidworks for the CAD and Mastercam for the Cam, everytime i needed to make a change on the CAD Model i have to start from the beginning on the CAM.
    them i tried TopSolid who is a intedrated CAD-CAM and i love it, i make a change on the CAD Model and automaticaly the change is made in the CAM Model, only have to regenerate the working operations. it´s easy.
    but i must say that my work is 90% of 2 and 2.5d, very litle 3D, for 3D Mastercam or Powermill have much more alternatives for the finish operations.
Page 1 of 2 12
  1. Could some one explain the advantages please
    By Donrecardo in forum Stepper Motors / Drives
    Last Post: 03-01-2008, 04:46 AM
  2. Meshcam - stand alone vs CAD integrated
    By harryn in forum Uncategorised CAM Discussion
    Last Post: 11-03-2007, 01:08 AM
  3. integrated stepper/driver
    By J Solinger in forum Stepper Motors / Drives
    Last Post: 10-09-2006, 03:08 PM
  4. USB Controllers & Integrated Stepper Motors
    By tt_raptor_90 in forum Stepper Motors / Drives
    Last Post: 01-29-2006, 11:59 PM
  5. Integrated motor/drive/controller
    By NEATman in forum Community Club House
    Last Post: 03-16-2004, 08:35 PM
