587,518 active members*
3,407 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Installing HAAS VF5 Ethernet Adapter
Results 1 to 2 of 2
    Jun 2015
    2
    Hi all, my company wants to set up 3 HAAS machines on the network, so I ran the CAT6 (crossover for NetShare). My boss just ordered the 3 Ethernet adapter setups ($1500 a piece!!!). All that came in the package was a little metal panel with a hole for the male to male Ethernet coupler, the coupler itself, and a patch cable. Of course there were 3 of each. My question is, can I send these back for a refund and just install this myself? From the materials provided, it just seems like you plug the patch cable into the coupler and the machine, then plug another cable into the other end of the coupler that runs to the network. Is there something I'm missing here or is it really that simple?
    Nov 2006
    490
    Re: Installing HAAS VF5 Ethernet Adapter
    The price for most software options (ethernet, expanded memory, etc) isn't for the hardware but actually for an unlock code that permits you to use the feature within the CNC control. The short answer is every Haas CNC has the same hardware within the cabinet, so you pay for the options on the software side. Yes it's dumb, yes you may not like it, but it's just the way it is (the alternative is much worse)
  1. Installing USB drive on 1995 Haas VF3
    By helfires688 in forum Haas Mills
    Last Post: 08-14-2014, 05:25 PM
  2. Serial / ethernet adapter - fagor 8055m
    By rwy in forum Fagor Automation
    Last Post: 02-16-2012, 02:03 AM
  3. Installing / Removing HAAS HRT210 4th AXIS
    By glenn105 in forum Haas Mills
    Last Post: 01-21-2010, 07:49 PM
  4. Replies: 5
    Last Post: 12-16-2008, 01:08 PM
  5. Installing Haas Indexing Head?
    By Moparmatty in forum Haas Mills
    Last Post: 05-27-2008, 01:46 AM
