586,071 active members*
4,360 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Installed a probe z-touchplate; now machine is going crazy on tool change (mach blue)
    Sep 2011
    26
    So I installed a touchplate which recommends using the mach blue screen.
    Pretty simple inputs, touch the wire to the plate; green light on the probe setting comes on like it should. The problem is when i hit the auto-z button; the router will go down a little slowly, then just drives itself into the material very quickly. The light is on so the circuit completes, but doesnt ever stop itself.
    That's problem 1. Problem 2 is running my previous G-codes, which I believe is on a tool change command wants to drive the router way out off of its limits in the x/y direction. I have the tool change location set to 10/10/3.... so i'm not sure what is causing this.
    None of this happened before the mach blue install, uninstalling it doesnt help the situation.
    35538
    Re: Installed a probe z-touchplate; now machine is going crazy on tool change (mach b
    Problem #1 is an issue with the auto zero macro.
    Problem #2 is probably an issue with the M6 macros.
    It may be that you are missing some settings in the screenset that the macros use??
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2009
    72
    Hi czwalga,
    I have tried many screens and the best by far in MY opinion is
    Once set up it works as it should every time.
    No affiliation blah blah blah
    Cheers
  1. Z axis is going crazy! "Mach Blue screenset"
    By Claytonc in forum Uncategorised WoodWorking Machines
    Last Post: 01-27-2021, 09:33 AM
  2. mach wanders off after tool change
    By dertsap in forum Mach Mill
    Last Post: 02-10-2014, 04:36 AM
  3. Mach3 and Auto Tool Zero / Mach Blue Probing by Big-Tex
    By TomiY in forum Machines running Mach Software
    Last Post: 11-15-2012, 09:24 PM
  4. Replies: 4
    Last Post: 02-01-2011, 03:10 PM
