I am using Artcam and have made a male piece using the inlay function and then cut a pocket using the same vectors using the female inlay function and both cut the correct shape but the female pocket is almost 1/16" to small. I've checked everything, but I don't understand Gcode, so I've checked all the specs in the program and everything seems correct. What should I do next? I think I'll try recutting the pocket in a scrap piece and see if it's the same. Any suggestions would be helpful, I could post the Gcoe if any one wants to see.
