587,558 active members*
3,150 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > incorporate 4th axis. help. simple task in my head but cant seem to implement it
Results 1 to 7 of 7
    Apr 2009
    8
    so I have been using featurecam for a couple years now and only messing with it as mucha s I can due to being busy and life in general. my question is how does one incorporate the 4th axis in say a drill cycle and index a certain amount. I'm thinking about doing hard line g code to do cuz its an easy task but I want to do it via cam layout. any tutorials or advice, I'm sure its simple but looking for pointers
    thanks
    the blueprint is in my head but could draw it if necessary..lol
    Re: incorporate 4th axis. help. simple task in my head but cant seem to implement it
    Apr 2009
    8
    What is the difference between tool dominant and setup dominant
    From featurecam's Help!!!
    Attachment 358264
    Apr 2009
    8
    thanks for the info. I'm having a hard time putting it into English. I have got this message myself and was hoping for somewhat of a dummy approach answer...lol...
    Also I was wondering is there a simple way to cut a given job in mirror image? I know it is in the transform option I think and have messed with this also a bit.
    thanks for all the replies.
    Mar 2005
    1
    I have similar problem. Just added a rotary table on the X-axis. Mach 3 operated all axis great but I can not get feature cam to simulated or to index the rotate table. I do not have a 4th axis folder in the posts directory.
    Pulling my hair out.
    Thanks for help and merry christmas
    Dec 2016
    7
    attach your model file and ill program an example for you
  1. Replies: 0
    Last Post: 08-02-2016, 07:23 AM
  2. Help needed to incorporate harmonic drives in a 4th and 5th axis head.
    By SpookyDad in forum Drilling- and Milling Machines
    Last Post: 07-03-2016, 02:05 PM
  3. Replies: 1
    Last Post: 03-20-2015, 01:52 PM
  4. simple task attempt limited success
    By George777 in forum Mastercam
    Last Post: 08-04-2008, 05:17 AM
  5. Simple Z axis solution for BP J Head retro
    By DennisCNC in forum Bridgeport / Hardinge Mills
    Last Post: 07-24-2006, 04:41 AM
