587,787 active members*
2,304 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > IGES Imports into Sprutcam
    Oct 2004
    159
    How is SprutCAM at importing IGES models from legacy CAD apps?
    I use Autodesk Inventor v5.3 (2002 vintage). I would like to be able to export IGES models from Inventor and then import them into SprutCAM. Would SprutCAM gracefully accept IGES data from an older CAD program, or would it turn up its nose and insist that I use a later version of IGES?
    This is about the last issue I need to resolve before I pull the trigger and buy SprutCAM.
    Thanks in advance.
    Aug 2005
    86
    You may not need to convert to iges.
    Sprutcam (with the addin for Inventor enabled) opens ipt.iam with version 7, although it is not working with 11 Pro.
    Check the Sprutcam site, I seem to remember them telling you what versions they support.
    That said, I have imported iges files with version 7 and 11
    Oct 2004
    159
    MarkWink,
    Thanks for that tip! I checked the SprutCAM site, and it appears that they do indeed have an add-in to read models from my version of Inventor. That is very good news!
    Thanks again.
  1. SprutCAM, Should have done this before.
    By borrisl in forum SprutCAM
    Last Post: 01-13-2017, 10:41 PM
  2. inventor file imports
    By keebler303 in forum Autodesk
    Last Post: 02-27-2008, 01:18 PM
  3. SprutCAM Questions
    By MichaelHenry in forum SprutCAM
    Last Post: 12-01-2007, 10:31 AM
  4. SprutCAM forum and web set down?
    Last Post: 08-06-2007, 03:24 PM
  5. SprutCAM 2007
    By S4 Monster in forum SprutCAM
    Last Post: 05-09-2007, 06:35 AM
