I LEARNED SOMETHING TODAY
I set a job up last night and aftet I ran about 4 parts I started losing the G54 position on the Y axis. Every part was about .010 off center and the more parts I ran, the worse it got. After about 8 parts, it was about .030 off.
After a thorough cleaning, I discovered the Y axiz stop had a significant build up of chips.
The cure was to run the X axis to its 18 inch limit and the Y axis to about minus 6 inches. That exposed the limis switch stops and I was able to give them a good cleaning.
I think a solution to this problem is to be careful where you blow chips, and if you start having a problem, STOP and clean the switches.
