587,460 active members*
3,686 visitors online*
Results 1 to 4 of 4
    Dec 2008
    3
    Hyd pump CB keeps tripping
    I have a hydrulic pack that keeps tripping the breaker. The machine is a Daewoo Puma 200. Im not sure how to check to see if its a bad motor or a restriction in the system causing the pack to get very hot and then shut down.
    Thanks for any ideas
    Dec 2003
    24220
    Measure current on all three phases for close match and no more than FLA marked on motor plate.
    If very unbalanced current then it could be the motor, if all phases the same then loading is most likely the cause.
    Al.
    Albert E.
    Sep 2009
    27
    Re: Hyd pump CB keeps tripping
    Another consideration to check as well is over time bi-metal type brakers that have heated up can alter there current carrying capability , making them trip at a lower amperage flow.
    A lot of machines came with this type of current protection.
    If your Full load amperage on all legs are close to each other and within your motors load specs and your not exceeding the capacity of the machine it would be something to look at.
    On some machines that don't have a dedicated motor braker but share all current loads through one primary braker then all electrical loads would have to be totaled to see if current exceeds the range of the braker.
    Dec 2003
    24220
    Quote Originally Posted by big iron View Post
    Another consideration to check as well .
    Hopefully after 5yrs the OP has solved the problem!
    Al.
    Albert E.
  1. SX3 Tripping RCD
    By Hamzter in forum X3/SX3/G0619/G0463
    Last Post: 05-30-2014, 08:39 PM
  2. G540 'tripping'
    By Claytonc in forum DIY CNC Router Table Machines
    Last Post: 01-01-2012, 12:48 PM
  3. tripping the overload
    By machinehead1970 in forum CNC Machine Related Electronics
    Last Post: 10-26-2010, 10:23 PM
  4. fuse tripping on 201 @ ~30 IPM
    By cyclotron in forum Gecko Drives
    Last Post: 05-14-2008, 08:54 PM
  5. Tig welder tripping GFI's
    By Dugg in forum Welding Brazing Soldering Sealing
    Last Post: 01-06-2007, 11:44 PM
