587,129 active members*
2,987 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco KM3P won't zero home in x axis
Results 1 to 7 of 7
Hybrid View
    Sep 2006
    300
    I have a Hurco KM3P .This morning when I tried to zero the table it went over in the X-axis and I got
    "Motion Error" & "Emergency Stop" errors. When it hits a limit switch usually I can bump it back manually and it is ok.
    This time I took the cover off ( power off, too) and turned the x axis ball screw by hand about 2" in the direction off of the limit switch. It still won't home position.
    Any ideas on what to check first?
    Thanks,
    JAckal
    Feb 2009
    6028
    Hurco used a funny little prox switch for homing, both our KM3's did the same thing. Both had low voltage on the 5 VDC line out of the power supply. I would check that first then adjust the power supply if needed. I always showed up on the X first, I think it was because of the longer run to the switch, loosing a little voltage normally.
    Sep 2006
    300
    Under,
    Thanks for the info. I checked mine at the switch and it shows 4.8 volts.
    How hard is it to adjust the power supply? Can I leave the volt meter hooked up the the wire feeding the switch and then adjust it up?
    Thanks,
    Jackal
    Feb 2009
    6028
    best to check on the power supply and adjust it. Just a little pot you turn, kinda buried under the grill, but you can get to it.. 5.1 volts seem to be the magic number.
    Jun 2008
    1104
    The early Km3Ps had a little board mounted behind the card rack with six opto-isolators on. If you have no joy with the voltages, it may be one of the optos. They were H11G2 types.
    Sep 2006
    300
    underthetire,
    Can you tell me where the 5v power supply is located?
    Thanks,
    Jack
  1. Hurco KM3P
    By ivanfed in forum HURCO
    Last Post: 04-20-2009, 10:48 AM
  2. Hurco KM3P HELP
    By winds1sj in forum HURCO
    Last Post: 12-20-2008, 08:44 PM
  3. HURCO KM3P ball screws?
    By CATCH22 in forum HURCO
    Last Post: 12-08-2007, 01:12 AM
  4. Need MasterCam post for a Hurco KM3P
    By oem3dcut in forum Post Processors for MC
    Last Post: 04-14-2007, 04:10 PM
