587,174 active members*
3,185 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > HURCO Air, Oil &E-stop
Results 1 to 7 of 7
    May 2022
    4
    Question HURCO Air, Oil &E-stop
    Hello guys
    Im new to this forum but I feel this will be a very huge help.
    I work for a watch component supplier. We work with a lot of old, yet great machine, and a lot of old and weird/outdated machines.
    My job is to retrofit these machines.
    This is quite problematic when we start to modify old machines with suppliers that do no exist anymore or old CNCs.
    Anyway, our subject here is an old Hurco VM1.
    It works good, a few modification were made to use it for grinding sapphires.
    However, there is one thing I dont understand. Maybe there is a reason but I honestly can't find the logic behind it:
    - If you stop the machine via emergency stop/power outage, all the axis stop in place. No issue.
    - If you have a failure of the air pressure (air compressor stops), or of oil pressure (never happenend), the machine would stop. And then, that's where it gets weird, after a few seconds, the Z (vertical axis) goes back up.
    In my opinion it's plain stupid. If the tools are working at this moment, we break everything (happened last week).
    I checked the electrical drawings and I can just get the airpressure sensor and place it on the EmergencyStop circuit. Same for Oil.
    (2nd weird thing is the Machine homing. Instead of going to X=0 Y=0 and Z=0, the machine goes to X=0, Z=0 and Y=355.6 (it calculate the 0 according to this maximum position). Pretty messy)
    Do any of you have an idea of why would they build the machine like that?
    Jonas
    Jun 2008
    1104
    Re: HURCO Air, Oil &E-stop
    Go to parameters and set the retract on interrupt to ‘no’
    May 2022
    4
    Hello
    Thanks for your message
    However, that is not an option in the parameters, as you can see in the 3pictures below!
    Attached Thumbnails Attached Thumbnails IMG_20220520_082538.jpg   IMG_20220520_082534.jpg   IMG_20220520_082543.jpg
    Jun 2008
    1104
    Look for ‘interrupt cycle Z retract’ in program parameters.
    What software are you on? No pics shown…
    May 2022
    4
    Hello
    Pictures should be ok now.
    I'll try to see the software version later today.
    Aug 2009
    1573
    Quote Originally Posted by Jonss View Post
    Hello
    ...make sure you Wait more than just a few seconds after Clicking "Upload"
    May 2022
    4
    Here I post them again, but the thing is I can see the pics, so I don't really know why y'all can't
