587,473 active members*
3,530 visitors online*
Thread: Huanyang VFD
Results 1 to 2 of 2
    Aug 2012
    126
    Huanyang VFD
    Hi All,
    Can anyone help?, I have a Huanyang 7.5kw 220 volt 34A Vfd, The Vfd is powering a 4kw 3-phase motor:
    Motor Type: ABB 2-pole, 50/60 hz, 4/4.6kw 2860/3460 rpm.
    The motor is wired in a Delta config, the Vfd is 240 volt input.
    Everything works as it should, but at low rpm (500 rpm) there is a loss of torque? so much so that I am able to stop the spindle of the motor with my hand?.
    The only way I seem to be able to get over the problem is to alter PD04 (Base Frequency) to a lower figure of 30hz?, I am a little unsure of this as the manual states that the base frequency should match what is on the motor plate (50/60 hz)
    Thanks for any help.
    Jan 2007
    1795
    under a frequency, it can not provide torque..
    what i using inverter... under 100 hz still spin the motor, but can not be used..
    i believe you need a gear ratio, migthbe timing belt reducer..
    best would be you email the manufacturer.. they answer you..
    i had issue with sunfar inverter and factory answered for my email..
  1. Another Huanyang VFD question
    By pacer in forum Phase Converters
    Last Post: 04-22-2016, 06:35 AM
  2. Help with Huanyang HY02D223B
    By stevespo in forum Spindles / VFD
    Last Post: 02-01-2014, 09:42 AM
  3. Huanyang HY01D523B help please?
    By Tony344 in forum Spindles / VFD
    Last Post: 10-22-2013, 01:27 PM
  4. huanyang burn!!help
    By edgas10 in forum Phase Converters
    Last Post: 07-03-2012, 01:16 PM
  5. Huanyang inverter
    By mdileva in forum Phase Converters
    Last Post: 06-18-2012, 03:24 PM
