587,626 active members*
3,342 visitors online*
    Howa, Fanuc T5, Retrofit
    Has anyone any experience with retrofitting a Howa, or other lathe, that has a Fanuc T5 controller?
    I would like to fit new X & Z servo drivers and change main drive motor to variable speed.
    Colin
    Mar 2004
    1543
    Can you tell us more about the X,Y servos and the spindle drive? Pictures and name plate info would be a great help. You should also check out exactly how the tool changer is powered.
    Karl
    Hi Carl
    We have managed to get it going again, so I guess a retrofit is put off for the moment.
    It would be a good project, as it has servo motors 8 tool stations etc. Still while the old T5 controller is working, it does what we need.
    Thanks for taking the time to reply, as you have before with lots of help on our Cincinnati retrofit.
    Regards, Colin (New Zealand)
  1. okuma howa nc5p fanuc 6t
    By atlasmax in forum Okuma
    Last Post: 10-18-2018, 11:41 AM
  2. Howa T5 Retrofit
    By cincinnatimachine in forum Fanuc
    Last Post: 05-19-2011, 12:57 AM
  3. Okuma+Howa Act3 w/10T Fanuc
    By dugculy in forum Okuma
    Last Post: 10-22-2010, 09:00 PM
  4. okuma howa fanuc 6t controler
    By cncperfection in forum Okuma
    Last Post: 07-25-2010, 02:38 PM
  5. Okuma Howa ACT 2SP V5 with FANUC 18T
    By marklosch in forum Okuma
    Last Post: 01-20-2010, 01:14 PM
