587,913 active members*
3,803 visitors online*
IndustryArena Forum > CAM Software > Surfcam > How to verify material removal in more than one job?
Hybrid View
    Apr 2009
    2
    This might well be very obvious an deasy, but I cannot figure out how to verify two jobs in a row in SurfCam Verify V3. Say I want to run the roughing job, and remove a lot of material, then verify a finishing job. It looks like the fininshing job starts with the full stock, and that makes it difficult to see wether it moves correctly. Is there a way I can cintinue removing material based on the result of another job, in SurfCam verify,.
    Cheers
    Best regards
    Jens Tandstad
    Jul 2007
    148
    During the verify operation, there is an Icon that says "save model". You can use this for what you are describing. Verify the rough operation and then save it using that button. Then when you want to verify the finishing operation, open the roughing model and use it from that stage. I hope this answers your question.
    Leo
    May 2009
    3
    You can verify rough cut and safe file in VERIFY
    Than for any other operations open saved file and verify next op.
    or you can create STL files and load for Stock material
  1. VERIFY ???
    By nelZ in forum BobCad-Cam
    Last Post: 12-22-2008, 02:28 PM
  2. Extra Material Removal...Help
    By Cartierusm in forum ArtCam Pro
    Last Post: 08-01-2008, 12:56 AM
  3. VERIFY
    By LYN BYRD in forum BobCad-Cam
    Last Post: 02-12-2008, 07:48 PM
  4. removal of 4140 HR Annealed material
    By Zipdrive in forum MetalWork Discussion
    Last Post: 01-12-2006, 05:51 AM
  5. material removal / air blower help
    By DrStein99 in forum DIY CNC Router Table Machines
    Last Post: 10-21-2005, 01:49 PM
