587,739 active members*
3,263 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > How to stiffen up the saddle on a mini lathe?
    Aug 2006
    3
    Question How to stiffen up the saddle on a mini lathe?
    I've had a 7x10 mini lathe for a couple of years now, and am looking for ways to stiffen up the carriage mechanism.
    I can mostly compensate for the lack of stiffness when I am working, but I find it nearly impossible to cut inside threads with the amount of flex I have..
    Any Ideas?
    Aug 2004
    98
    do you have the whole thing bolted down? That helps some with over rigidity, but probably not so much with the saddle.
    Aug 2006
    3
    RE: Bolted down
    I have it bolted to some very stiff urithane vibration mounts bolted to a sturdy work bench, so I this could be a source of bed flex. I have a chunk of 1" 7000 series aluminum that I could use as a mounting plate, so I guess I will give that a try.
    I am thinking I might have the gibbs out of adjustment, or the bolts for the protractor mount might nt be as tight as I was thinking they were ( found the protractor bolt Idea in another CNCzone post)
    The slide travel is fairly tight, but I think I should probably take the whole thing apart and have a good look at it. Same goes for the protractor. I find my self adjusting that fairly often, and it is tedious to get the screws tight again.
    Any one have a mod out there for the protractor mount?
  1. Replies: 15
    Last Post: 05-05-2011, 11:59 PM
  2. Mini lathe and mini mill spindle?
    By ZipSnipe in forum Uncategorised MetalWorking Machines
    Last Post: 10-15-2010, 02:13 PM
  3. Concrete to stiffen mill upright?
    By Tristar500 in forum Benchtop Machines
    Last Post: 11-13-2006, 04:21 AM
  4. stiffen up as lathe
    By HIGHtungsten in forum Mini Lathe
    Last Post: 08-28-2006, 06:00 AM
  5. Anyone have a mini cnc lathe or medium sized cnc lathe
    By nymachinist in forum Mini Lathe
    Last Post: 01-24-2006, 03:36 AM
