587,747 active members*
3,007 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > How to set contour overlap on Haas machine?
Results 1 to 8 of 8
    Jul 2014
    222
    Machine is older, it is actually Mikron Haas VCE 500, but the control is very similar/equal to newer Haas mills.
    We have problem with this machine that it doesnt finish contour (toolpath) very precise, for example if you make a circle it will leave a small amount of material around start/end point of mill toolpath (circle).
    So we deal with this in CAM software, to extend this toolpath for example by 2mm... or make 2 circles instead of one.
    But this problem occurs only on this older Haas machine, we have 2 newer and they dont have this problem.
    Is there a parameter or setting on the machine which could overlap this contour for some amount so this problem wouldnt occur?
    Thanks in advance.
    Nov 2020
    1
    Re: How to set contour overlap on Haas machine?
    I am very happy to find this information. Thanks for sharing this knowledge with us. https://www.wiretree.ca/
    Dec 2013
    5716
    It would seem to me that setting a proper leadin/leadout in the CAM setup would solve this problem.
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2014
    222
    Quote Originally Posted by Jim Dawson View Post
    Nope, that is not true. Same program on newer machine doesnt have this problem
    Aug 2009
    1573
    ...try using G61 Exact Stop code or use G09
    Jul 2014
    222
    That is not the solution its a patch. I want to fix machine not change gcode
    Dec 2013
    5716
    Quote Originally Posted by allenp View Post
    I guess the fix might be to call Haas and get a software/hardware upgrade to match the newer machines. Or at least see if they can suggest a parameter change that would fix that.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2024
    1
    I am very happy to find this information. Thanks for sharing this knowledge with us Visit: https://thesimpleindian.com/
  1. HAAS Error 369 on Outside Contour
    By brcasey3 in forum G-Code Programing
    Last Post: 06-02-2017, 02:05 PM
  2. Overlap on my 1390 Omni laser machine
    By PCALLA in forum Omni CNC
    Last Post: 06-17-2016, 02:49 AM
  3. Treading overlap
    By Atilano in forum Community Club House
    Last Post: 01-17-2014, 03:39 PM
  4. Lead Out Overlap
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-23-2008, 02:47 AM
  5. Laserlabs Contour machine blues.
    By thebackshed in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-21-2008, 01:06 PM
