587,143 active members*
5,519 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How to manually change/edit Series 0 diag parameters ?
Results 1 to 2 of 2
    Sep 2019
    26
    Question How to manually change/edit Series 0 diag parameters ?
    I'm recovering from lost parameters on a '93 Fanuc OMF used in a leadwell mcv-0p. I cannot get the diag parameter, like oil pump timers (D345, D350), set from the mdi. I have the key switch set to on, the pce bit set to 1 and the estop pushed in.
    When I enter a value and hit the INS key, the diagnostic value will not change. I understand some values are status and cannot be changed, however these values are in the parameter set and look like they must be set.. Am I doing something wrong ? not setting some other bits to change the value ?
    thanks..
    Sep 2019
    26
    Re: How to manually change/edit Series 0 diag parameters ?
    Just a quick update:
    Thanks to Bruce at Tristarcnc, the "program protect" key must be in the OFF position to change the Diagnostic parameters.
    Thanks Tristar
  1. Replies: 7
    Last Post: 08-13-2014, 08:14 PM
  2. Replies: 0
    Last Post: 09-20-2013, 02:44 AM
  3. How to change tool Manually?
    By happytriger2000 in forum Mach Software (ArtSoft software)
    Last Post: 08-01-2013, 08:55 PM
  4. Using Gedit without EMC2 to manually edit Gcode with syntax
    By mouratoglou in forum LinuxCNC (formerly EMC2)
    Last Post: 07-25-2009, 08:36 AM
  5. Manually Change Endmill
    By DroopyPawn in forum G-Code Programing
    Last Post: 11-20-2007, 08:04 AM
