587,434 active members*
3,301 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > How to flatten a 3D curve for use as a boundry geometry
    Apr 2010
    260
    I am trying to create a boundry condition for a 2D pocket. As I select around the part the boundry I am creating has a changing z value. As a result BobCad will not allow me to use this as the geometry. How can I flatten the curve(Z constant) or project it onto a plane so I can use it
    www.machmachine.com
    Mar 2005
    368
    1. Create temporary plane above the part with Surfaces > Rectangular Plane
    2. Use Other > Project Curves to Surface to flatten curves onto temporary plane.
    3. Delete or blank the temp plane.
    Notes: I like creating a new layer just for the projected curves.
    It's usually quicker to project just the curves you need rather than window selecting all the extracted edges and sorting them later.
    Watch that you don't miss any small path segments.
    Apr 2010
    260
    great I will give that a try
    thanks
    www.machmachine.com
  1. Using fly cutter vs End mill end for flatten material
    By Micro Milling in forum MetalWork Discussion
    Last Post: 04-01-2010, 01:07 AM
  2. Best end mill to flatten steel
    Last Post: 12-10-2009, 07:09 PM
  3. Flatten/Squash G-code to constant Z
    By 94vette in forum G-Code Programing
    Last Post: 05-20-2008, 06:42 PM
  4. Mach 3 blip on boundry line
    By keen in forum Mach Software (ArtSoft software)
    Last Post: 06-23-2007, 12:49 AM
  5. Boundry Cuts?
    By 12jbowler in forum BobCad-Cam
    Last Post: 02-28-2007, 09:10 PM
