To put it simply---no. You can't use g-code to remake a part file. BobCad, like any/every other program will not know what you were doing with the code in the first place. Did you pocket out a square hole, but did not go to the bottom, etc. etc.. What size was the endmill etc. etc.
If you don't have a back-up part file, then start drawing and re-doing your part. You can bring the g-code back into Predator and watch the lines fly around the screen in Back-Plot, but it will get you nothing.
Do a search on your computer for the files' name and you may find it in a back-up folder somewhere.
Mike
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
