I have a vibratory deburing machine- I got it used, but it is a BurrKing- you could look on their website. The vibratory machines are expensive- Not sure exactly why, although mine does have a 1hp motor, so its pretty powerful, and a bigger capacity than little rock tumblers.
What I have found is that it makes sense to ask the salesman- look in the yellow pages under deburring or abrasives, call around until you find a distributor that sells the ceramic media, and describe the type and size of part you run, and he can hook you up with the right size and shape. I use a double ended pyramid, about 3/4" long, and they work well on stuff that is at least a couple of inches long.
One thing I really recommend is buying a gallon of soap/anti rust stuff from the suppliers- I have one gallon that has lasted me years, as it thins down with water something like 25 to one- but it really helps- it lubes the whole process, and makes it easy to clean off the parts after you take em out.
I have heard of EDM shops that run whole shelves full of $100 rock tumblers, and leave the parts in for a day or two. Long times seem unavoidable- sometimes when I run stainless parts, that have been waterjet cut with a sharp edge, I leave em in at least a day. Mild steel is usually more like 4 to 8 hours.
