Most of these type of fans have a fair tolerance so If it were mine I would run at 28v.
All resistors basically have the same effect, they limit current, which in turn causes a volt drop or potential to appear across the resistance. Saying a 'current limiting resistor' and 'voltage reducing resistor' is like expressing the same thing in a different way.
Actually using a resistor to drop voltage is very wastfull as you can see by the wattage (heat) dissipation of the resistor.
Al.
Albert E.
