587,546 active members*
3,578 visitors online*
Results 1 to 4 of 4
    Oct 2005
    90
    how to convert file to work on flow
    Well I'm pulling my hair out. I made this shifter linkage design for a friend but the waterjet can not handle splines. Ive tried making them polylines but that's not working either. What do you do to make a file like this work in a Flow Waterjet?
    Please take a look at it. I would like to do more in the future and need the right method or software to do it.
    Jul 2010
    46
    Re: how to convert file to work on flow
    I typically pull the file through rhino and export with the "CAM Imperial" template
    Oct 2005
    90
    Can you try pulling my file in and exporting it? I would like to give it a try.
    Jul 2010
    46
    Quote Originally Posted by Traceman View Post
    See attached.
    Attached Files Attached Files
  1. Conversion of G code to ORD file for Flow Mach 2
    By junaidabbasnust in forum Alphacam
    Last Post: 07-21-2016, 05:36 AM
  2. How do you convert STL file from 3D printer to G-code or a CNC desktop mill file
    By imperial90303 in forum Uncategorised CAM Discussion
    Last Post: 01-25-2015, 08:37 PM
  3. Convert DWG file to DSTV file
    By benamer in forum Community Club House
    Last Post: 07-02-2013, 02:34 PM
  4. Solid Model Work Flow
    By aldepoalo in forum BobCad-Cam
    Last Post: 11-19-2012, 08:34 PM
  5. Software work flow
    By Darroll in forum DIY CNC Router Table Machines
    Last Post: 01-17-2008, 01:44 PM
