587,380 active members*
3,791 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How to control the water coolant by mach3?
    May 2007
    250
    Hello Experters,
    I try to control the water coolant by mach3. I buy the water pump (0.5 hp) at 220 volts. If I plug 220 volts,the water pump will run immediately.
    I know M-code,M07 is turn on and M09 is turn off for the coolant.
    Who can advise me for the simple circuit to control the coolant?
    Hope your help
    Mongkol
    Feb 2009
    2143
    You need to use a relay to switch the 220V. That relay would be controlled by the breakout board on your parallel port.
    May 2007
    250
    Circuit ?
    mcphill,
    I know solidstate relay, It may be another choice.
    Could you pls advise me for the simple circuit ? or what website sell the PCB of this case and connect to the breakout board as well ? Pls advise.
    Mongkol
  1. Water based coolant - suppliers in Australia?
    By LeonM in forum Australia, New Zealand Club House
    Last Post: 11-13-2008, 10:51 PM
  2. Water Based Coolant
    By classictom in forum MetalWork Discussion
    Last Post: 08-27-2008, 12:04 AM
  3. Coolant, mixing in more water
    By smellyfeet in forum Uncategorised MetalWorking Machines
    Last Post: 06-30-2008, 12:39 PM
  4. Water-based coolant/lube use and handling
    By jim_stoll in forum Benchtop Machines
    Last Post: 11-13-2007, 07:49 AM
  5. Water Pump control
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 07-08-2005, 12:52 PM
