587,189 active members*
2,430 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How to clean dried coolant, oil, and chips?
Results 1 to 9 of 9
    Aug 2012
    279
    Getting a used machining center that has a significant buildup of crud in the enclosure. Need to remove the enclosure but cant even see where some of the fasteners are because of a buildup of chips, coolant, oil, etc especially in the corners. What's the best way to remove this? Just chisel if off? Put something on to loosen it up? The machine has been sitting for at least 2 years so it is all dry.
    Dec 2013
    5714
    Re: How to clean dried coolant, oil, and chips?
    Kerosene or diesel? For quick action, brake parts cleaner works pretty good, I like the non-flammable stuff. That and a wire brush. Available at any auto parts store.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2017
    49
    Quote Originally Posted by Jim Dawson View Post
    I would highly recommend not using anything that produces strong vapors inside the enclosure. You won't last 5 minutes using brake cleaner inside of there.
    Oct 2017
    49
    Just get to the point where you can remove the enclosure and then take it outside and power wash it (tyvek suit recommended). For any parts you can't remove to power wash take a paint scraper, some sort of scotchbright pad and an alkaline cleaner and go to town.
    Mar 2017
    411
    Could you use some Gunk Engine cleaner? It will dissolve the grime so you can flush it out with water and it is easy on plastic, glass, and rubber.
    Jul 2005
    163
    Use STP Superclean. It actually dissolves the caked-on oil. I have used it to clean numerous machines, and it works really well. I have even managed to get stuff removed with it that wouldn't respond to isopropyl, nor acetone. You need to use nitrile gloves when using it heavily, but it's not really bad. It doesn't stink, and from personal experience, I can tell you it does what it says on the bottle. No affiliation with the company, just a satisfied user of the product.
    Aug 2016
    132
    My method has been to drown the machine in WD40, let it sit overnight and take a putty knife to it.
    Dec 2005
    160
    I have used oven cleaner on a super gacked up old sheldon I bought
    Oct 2009
    45
    If the Crud is a build up of water based coolant & swarf, the BEST way to dissolve it, is to mix up a fresh batch of water based coolant in the proper ratio and spray it on the crud till it dissolves. I have found that this by far is the most effective, and the fresh coolant has rust inhibiting properties - do not use plain water, it will not dissolve as effectively and will cause everything to rust .
    Harsh chemicals will not dissolve aqueous based coolant residue... likewise if the build-up is from a chemical based coolant, then aqueous (water-based) will have no effect.
  1. Tormach Users, How do you clean up your chips.
    By Stevos758 in forum Tormach Personal CNC Mill
    Last Post: 05-02-2015, 04:41 PM
  2. Scrap value quesiton, chips vs chunks. Coolant mixed with chips?
    By trialanderror in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2013, 12:08 AM
  3. Keeping Coolant Clean?
    By donl517 in forum Fadal
    Last Post: 02-01-2010, 10:31 PM
  4. My encloser chips & coolant will never get away!
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 11-20-2009, 08:01 PM
  5. chips in coolant sump
    By gromit68 in forum Haas Mills
    Last Post: 06-26-2008, 02:28 PM
