587,719 active members*
3,494 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > How to check the performance of an unknown CNC
Results 1 to 7 of 7
    Jan 2011
    24
    Attachment 244722
    Hey guys. I joined my dad very recently in his shop. I asked my dad and workers on how the performance of the machine is?.They told me it's working fine.
    Me: Is this a good machine?
    Reply : Yeah we are using this from 2009. It's good
    Me: What jobs have you run on the machine? What accuracy can you achieve?
    Reply: This machine is used for a single cast iron job. We have to machine volumes of 10000 per month. At times it goes upto 16000. So we are running the same job from 5 years. We did try to run few other jobs, we machined hubs for gears, but had to dedicate this to the customer since we are the single source. So generally speaking it's being using to machine cast iron.
    Me: What additional features does the machine have?
    Reply: Its has through coolant. But we hardly use it. The filters get clogged and the operators are negligent. Or worse, they show attitude when asked. Also the job doesn't require through coolant.
    Me: What operations are performed on the job?
    Reply: Spot facing, drilling, tapping
    Me: What tolerance is being achieved?
    Reply: Hole true position within 0.1mm
    Me: This tolerance is easily achievable. We can run this on a drilling machine.
    Reply : Try managing the labour for those volumes and you will run away. Also each job has 9 drilling operations and tapping for one hole. It's highly tedious for anyone to handle those operations to keep up with demand.
    Me: So now if I want to run precision jobs is it possible? Is this a production machine or tooling machine ?
    Reply: We have never ventured out asking for NPD( new product development) I am already 55 and I can't bear to hear the stupid questions from those purchase idiots who know nothing about machining and are programmed to cut prices.But I believe it should not be a problem ? I have no clue if its meant for tooling or production.
    Me: So how can I check the accuracy of this machine? It's running from 5 years? There has to be some wear and tear.
    Reply: We don't know. You come up with few ideas. Show your performance. I had no one to guide me when I was your age. Find out.
    Guys I know it's a long post. I tried to make it as interesting as possible. Hope you got the context for which I have asked this question. Appreciate any feedback .
    Here to learn, share and stay.
    Nov 2010
    89
    Re: How to check the performance of an unknown CNC
    You could measure backslash on the ball screws, runout of the spindle, strightness of the guides and the ballscrew to see how straight the machine and also see of it have had a major crash
    Jan 2013
    17
    on everything Riddersholm suggest i would add Ballbar measure, best way to see geometry status.
    Darko
    Jan 2005
    15362
    acejunker
    If it has had no maintenance in 5 years, you are doing 10,000 parts on it a month (Plus), then you should get/buy another machine as a back up so you can do other work as well, & take that machine out for some maintenance, it's more than payed for with that work load it has had
    One of your answers you said the holes could be drilled on a drill press, & hold 0.1mm true position, ( you are dreaming ) If the drill press was CNC controlled yes it would be possible, but a regular Drill press this would not be possible
    As Darko D. has said a Ballbar test will check the accuracy/condition of the machine all in one setup not much down time to do that, the Table would have to be cleared & the spindle cleaned
    Mactec54
    Jan 2011
    24
    What would it cost to invest in a ballbar test kit.. Worth the investment if you have only one machine?? What cost to get the test done from a service engineer??
    Jan 2011
    24
    Also what test do you do for a CNC lathe performance test?? A ball bar test for lathe also??
    Jan 2005
    15362
    Quote Originally Posted by acejunker View Post
    Yes just a different setup,here is a contact for India, you would not buy one, they are very expensive, you get the company to come & do the tests, up to $300 per test, Your Hurco would of had a Ball-Bar test when it was built, you may find it with the machine manual/ documents Etc, you can then compare the two if you get it done, this will tell you what kind of shape your machine is in
    T +91 80 6623 6000
    E [email protected]
    Mactec54
  1. Unknown G code
    By cnczoneguy in forum G-Code Programing
    Last Post: 10-26-2012, 05:23 AM
  2. Unknown object
    By octaneman in forum MetalWork Discussion
    Last Post: 03-27-2012, 03:44 AM
  3. Unknown Spindle
    By bwb58 in forum Benchtop Machines
    Last Post: 12-16-2010, 08:19 AM
  4. unknown
    By ajmazzsr in forum Shopmaster/Shoptask
    Last Post: 06-06-2010, 06:32 PM
  5. Unknown lead nut?
    By slavkok in forum Linear and Rotary Motion
    Last Post: 12-05-2005, 04:49 PM
